It is currently Thu Oct 01, 2020 10:56 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: My N GAUGE Loco,s
PostPosted: Fri May 14, 2010 12:40 pm
more
PostPosted: Fri May 14, 2010 12:45 pm
more
PostPosted: Fri May 14, 2010 5:42 pm
Looks like all you have to do is dust it off and run some trains.
PostPosted: Fri May 14, 2010 6:25 pm
Yes, I do have a track burner, it sends a heat out along the track to help to keep it clean, also a track rubber and a small loco that has fine sand paper disc,s under the body on small springs, as it goes round it sands the rails.
But it will take ages to get it working again, all the locos are o/k ,but the coaches and the wagons will need a clean.
PostPosted: Sat May 15, 2010 5:55 pm
more
PostPosted: Sun May 16, 2010 5:28 pm
Ron, that is a pretty good size layout! Very nice.
BTW what do you mean by tracker burner?
PostPosted: Mon May 17, 2010 5:21 pm
Hi, I will try to take a photo of the 2 I have.
PostPosted: Tue May 18, 2010 8:56 am
The relco has 2 cables in and 2 cables out to each side of the track, the current burns off any dust that lie,s on the track, makes it easier to keep track clean.
You can fit it any where under your controllers board, so you dont see the cables.
PostPosted: Wed May 19, 2010 12:21 pm
OK, I have heard of that. It uses high frequency current to do the job. How well does it work?
PostPosted: Wed May 19, 2010 12:58 pm
For me it worked very well, the long sections of track at over 100ft would have needed a lot of work to keep clean, I have 2 on the whole layout. :D :D :D
